Hello,
I've started playing with 3.0.1. Made a fresh install, I copied my old "chases" directory into the new one. If I try to open a sequence in the editor, they show up and open OK. But if I try to insert a sequence in a cue (cue options -> insert sequence), the list is empty. Strange?
And a slight problem with the forum: messages are not sorted by date anymore. I checked my preferences and they are ok, sort by date.
Thanks.
3.01 problem and forum problem
Crrispy
- Bug Zapper...
- FreeStyler Version: 4.1
matt
- Admin
- FreeStyler Version: NULL
Re: 3.01 problem and forum problem
For the Forum Issue, Clear out your Temporary files on your Web Browser. A Program i recomend to do this is called CCleaner.com
Matt Hankosky
flickr.com/photos/mattxhank
Crrispy
- Bug Zapper...
Thanks but I already had tried this, including cookies, and it didn't work. I also just tried with Firefox and it's exactly the same, so definitely not an IE related problem. Update: I suspected my english Windopws XP, but just tried on a different machine with french XP, same problem. Really strange, it used to work.
For the cue problem, I just found out by myself: have to open each scene in the editor and re-save it. This generates a .chb file with the same name, and the cue list only "sees" .chb files in 3.0.1
Update: all the pan/tilt movements in bezier shapes are lost in the "conversion" process, and also multi step sequences, only step 1 remains. I can do everything again
Difficult upgrade.
Crrispy
- Bug Zapper...
Settings are definitely like this, I never changed the default settings in this area.
