I'm running FreeStyler 3.0.1 on an HP Pavilion dv7 laptop (Vista Home Premium x64) with an Enttec Open DMX interface to control a relatively large system. It all works great, but now I'm trying to add MIDI control and have run into some difficulties.
My MIDI setup:
ART X-15 Ultrafoot
Yamaha MIDI USB interface
MIDI-OX
LoopBe1 Virtual Interface
I use MIDI-OX to translate program change data from the X-15 into MIDI note-on/note-off messages through the LoopBe1 interface to FreeStyler. So for example when I select Patch 1 (MIDI Program 0) on the X-15, MIDI-OX sends MIDI Note 0 on with velocity of 127 to FreeStyler, then after a 250ms delay it sends MIDI Note 0 off with a velocity of 0. This configuration seems to work well, for example I can set a patch for Submaster 1 Go and another for Submaster 1 Back, and when I select those patches, Submaster 1 will move forward or backward as expected. I've also configured the Bypass button on the controller to work with the blackout feature in FreeStyler.
I'm having two problems, however. The first is that while FreeStyler recognizes and allows me to assign MIDI Note 0 to a control, in use it seems to completely ignore it. I can get around this by just not using MIDI Note 0, but it's a bit annoying - is there a way to get around this?
The second problem is that when I assign a note to one of the Toggle Submaster functions, that note will run the submaster on the first press, but will not stop the submaster on subsequent presses - the only way I can stop it is to click the Stop button using the mouse. After doing that, pressing the note will run the submaster again... Basically what I'm saying is that from what I can tell, the Toggle Submaster X functions behave as Run Submaster X, with no functionality available for a Stop Submaster X. Has anyone else experienced this, and if so, is there a way to get around it?
Thanks in advance for any help!
MIDI Control Problems
- Hambone
- Band Member
- FreeStyler Version: Beta
- I Use FreeStyler for: Band
http://two-for-flinching.com
- LJ_krede.dk
- FreeStyler Version: 3.3.7
Re: MIDI Control Problems
as Freestyler is now, you can't stop a submaster via Midi.. I have asked Raph some time ago if he would change this so you can use one midi note to start and stop a submaster, i will ask him again and say we are at least two guys who wants thisHambone wrote:The second problem is that when I assign a note to one of the Toggle Submaster functions, that note will run the submaster on the first press, but will not stop the submaster on subsequent presses - the only way I can stop it is to click the Stop button using the mouse. After doing that, pressing the note will run the submaster again... Basically what I'm saying is that from what I can tell, the Toggle Submaster X functions behave as Run Submaster X, with no functionality available for a Stop Submaster X. Has anyone else experienced this, and if so, is there a way to get around it?
An alternative is to set the intensity to zero when you want to stop the submaster, or make a sequence that stops the certain fixtures you have in the submaster.
/LJ_krede.dk
Aalborg, Denmark
Aalborg, Denmark
