Hi there Hope that someone can help me.
I'm using freestyler and it's working just fine. My problem is that I want to change my programs "that I have saved into Cue" whit my midi keyboard (Triton)
I have tryed to set up the midi part and it seem to work, the midi notes are reg by freestyler. (Setup choise = midi notes to "sequence 1 to 20"
However when I try to change the programs that I have saved into the cue, with my keyboard nothing happens?
That the problem, as far as I can see, could be ore is the vel, but how can I make it work ?
Best regards Spens Denmark
Midinote to freestyler Topic is solved
