Suntrix Missing after Install
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Post by matt »
When you Install the Suntrix Plugin, by Defualt it installs to c:\FreeStyler .
If you have Freestyler Installed in the Defualt Location of C:\Program Files\Freestyler, you will need to Drag the "plugins" folder from the C: drive on to the Program files folder. Then re-Launch Freestyler.
Thanks MMAX for This Tip!
Matt Hankosky
flickr.com/photos/mattxhank
kikabyte
Re: Suntrix Missing after Install
Post by kikabyte »
What exactly is Suntrix?
I think i may have missed the point on installing this?!?
Ta
Chris
matt
Admin
Post by matt »
Currently, Suntrix is available to BetaTesters Only. It allows you to Matrix Multiple Fixtures together to create a "Light Wall" with Moving and Synced effects.
Matt Hankosky
Return to “Suntrix & LedTrix plugin”
