Hey, New to this but have created a fixture file for the q-roll 250 everything is working except the pan/tilt movement control, does someone mind having a look at it and see if i need anything else at all
Thanks,
Aaron
Heres the manual: http://www.chauvetlighting.com/products ... _ug-65.pdf
Thanks Again
Help with Q-Roll 250 Topic is solved
azza09
matt
- Admin
- FreeStyler Version: NULL
Re: Help with Q-Roll 250
Fixed.. you had the pan and tilt in the wrong spot.. you cant put anything in the 16 bit if you dont have anything in 8 bit..
Q-Roll 250 - Fixed.pff- (68.38 KiB) Downloaded 58 times
Matt Hankosky
flickr.com/photos/mattxhank
