Uploading chases to the Martin 2510
kevvywevvywoo
Just started using FS
FreeStyler Version: 3.5.7
Post by kevvywevvywoo »
I have a V2.00 Martin 2510, for info, this is the minimum firmware version that will work with DMX...earlier versions only work with Martin protocol.
I have uploaded several chases (sequences) into the 2510, but I'm not sure if I'm doing something wrong, or whether this is correct: If I upload (eg) 10 freestyler sequences, the 2510 loads freestyler seq 1 as the SU (startup) seq, and then loads freestyler seq 2-10 as martin 01-09. So when you turn the 2510 on, it flashes '09' to say that there are 9 sequences available.
Also, when selecting a new seq to run on the 2510, it should flash the new sequence number and you confirm with the Enter key. This doesnt always happen sometimes it just jumps to the new sequence...though it always did before using freestyler!!
Can anyone contribute to this? Cheers
Kev
dmxlighting
FreeStyler Version: beta
Re: Uploading chases to the Martin 2510
Post by dmxlighting »
Ive got a 2510 for testing. I will have a play and get back to you. Its been a long while since I used it so cant remember off the to of my head.
