Position Preset function Topic is solved
fcpsound
Post by fcpsound »
Can anyone tell me if there is a functions in FS to create POSITION PRESETS? I know this was discussed before but I cannot find it in the current version of FS.
Thanks Very Much
Jan
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Re: Position Preset function
Post by matt »
Are you talking about for All your Lights, Or for Moving Lights?
If its a Preset for 1 light, you could do a Macro or a Cue...
Matt Hankosky
flickr.com/photos/mattxhank
fcpsound
Post by fcpsound »
It would be for moving lights. For example, in Martin Light Jockey, you can have a list of position presets (position of the mirror). Each sequence or scene that utilizes the moving lights can be associated to one of the position presets. In this way, you only have to adjust each position preset once instead of having to adjust the position for each scene.
Thanks,
Jan
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
Freestyler does have this functionality. When creating a your cues the icon on the top right (looks like two moving heads linked to a list)
if you click on that you can save a current scene as a preset.
This preset can be applied to any scene or cue.
Editing the preset will update all the cues and scenes you have created.
This works for overrides as well. its is a little buggy as is a fairly new feature and sometimes some attributes are missed (Mostly colour information)
fcpsound
Post by fcpsound »
Thank you for your input. I will try the function that Mattotone has suggested.
Jan
