Help Creating Hulk150 Profile Topic is solved
carguy411
Post by carguy411 »
can anyone help me create a profile for the Hulk150 moving heads.
i just started using frestyler and still learning..
here is the manual for the dmx values the ligh uses http://www.eliminatorlighting.com/pdffi ... %20150.pdf
thanks .also how do i upload it once i downlad a profile??
also the gobo images arent in the manual how would i update the profile once complete
thanks guys this is a great forum
dmxlighting
FreeStyler Version: beta
Re: Help Creating Hulk150 Profile
Post by dmxlighting »
Hi and welcome to Freestyler.
At this stage of your learning of FS I am gonna suggest that you make the effort to build the profile yourself. Its worth it in the long run.
Open up the fixture creator program. (found in the freestyler folder from your start button).
To then get an idea as to what to do, load a premade profile and look at how its done. Its not hard and Im sure you will get it quite quickly.
If you then get stuck, upload the file you have started and someone will help you with it.
Cheers and good luck!
carguy411
Post by carguy411 »
i tried to do it but not sure where to put the chanel numbers and value. it doesnt really say each ch. theres like 3 dif gobo chan.s so its trhowing me off
is there a tutrorial on here
carguy411
Post by carguy411 »
thanks i been trying all day from 3 till 11 . just doesnt seem to be workin right.im doing the hulk and thr roboscans 812. when i import them into the 3d window it crashes the program, when i use the ones in the library it works fine.
also for some reason when i open the 3d the lights seem to be shaking back and forth and freak out. the gobo shake feature isnt on
can some one please help me out with the profiles :oops:
Post by LJ_krede.dk »
upload your fixture file so we can see whats wrong..
by the way: You cant count on the magic 3d easy wiewer has the right setting for your light,, you have to check that in the ScanLibrary program
dmxlighting
Are you trying to use an FS fixture profile in the 3d Vis?
If so, this is never going to work ! You need to use the Magic 3d fixture creator (which is harder to use than FS FC). So infact you would need to make 2 profiles.
FreeStyler Version: N/A
Post by remco_k »
LJ_krede.dk wrote:update your fixture file so we can see whats wrong..
I think you meant upload ? :mrgreen:
ups :? but you guys know what i mean ;)
i have corrected it
This is a 100% fully working Roboscan 812 file
carguy411
Post by carguy411 »
the roboscans worked but when put into the 3d it still is crashing the 3d generator. whay is that.
aslo im still having trouble with the hulk150 profile. i choose a color and it moves and when i move changes gobo. i checked the setting profile and its set to the manufactures specs
dmxlighting
carguy411 wrote:the roboscans worked but when put into the 3d it still is crashing the 3d generator. whay is that.
Can you post the spec of the PC you are using. Might be that you dont have enough processor muscle to run the vis.
carguy411
Post by carguy411 »
im not sure what the problem is
i have a brand new hp 4 gig ram 320 gig harddrive core2 duo. vista .could the vist be throwing it off.
but when i use other light profiles it works ok
only when i put the hulk150 i made or the roboscans.go figure for the 2 lights i need
