American DJ Revo Sweep and Stairville MATRIXX FL 100 Topic is solved
Alec25283
Post by Alec25283 »
HI guys and gals,
Hoping someone can help me out. Trying to create the fixtures for these two lights but just don't seem to be able to get it right.
DOes anyone have these files for freestyler or could someone create them for me.
I would be so appreciative if you could, I hve tried myself for the last two weeks but just cannot get it right. maybe it's me in fact more than likely
many many many thanks
Alec
Re: American DJ Revo Sweep and Stairville MATRIXX FL 100
Post by LJ_krede.dk »
FreeStyler Fixture Files - Help & Support wrote:
Fixture File Help & Support, This is not a Request forum we are here to help you not work for you...
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
Regarding the Revo Sweeps - are trying to create it in 3 channel or 28 channel mode?
You will have better success if you make macros for this effect. Control of effects like this is never straight forward especially when there are so many channels.
One way to do it would be to make a profile to control the first 4 channels (in 28 chan mode) via some macros then make a separate profile to control RGBW (red green blue white). Then in FS select the control profile and 6 RGBW profiles per unit. Sounds complicatedbut this is how I would do it on my Zero88 Leap Frog and it would work for you in FS.
If your going down the easier 3 channel route the just make some macros and away you go...
I will at some point need to make a profile for these myself as I have just started fitting them in clubs and I use FS to test.
FreeStyler Version: N/A
Post by remco_k »
Alec25283 wrote:HI guys and gals,
If someone ever did make this fixture, it would probably be found on this forum. So if its not, you need to create it yourselves.
Corresponding to the forum rules, we are not going to create the fixture file for you.
You _have_ to learn doing this yourself, as otherwise there comes one day you really need the knowledge and have just minutes to create something...
Its easy to make the fixture file for any fixture, you just need to understand the basics. And you learn those basics by making the fixture file. :mrgreen:
You're telling you have been busy for the last two weeks, then please post the fixture file (.pff) here and the manual of the fixture (containing the DMX channel description) itself and tell us what fails or don't work for you. Also note (if applicable) in what mode you want to use the fixture.
Then you'll get more likely proper help, and better: you'll understand.
