Cue List Buttons and SubMasters
mobilegreg
Just started using FS
FreeStyler Version: 3.0.1
Post by mobilegreg »
I am not sure how to add a sequence to the cue list buttons and submasters. I have successfully created several chase sequences that all work fine in the fast cue switcher, however I have not been able to add them the cue list buttons or the submasters. What do I need to do? Also the master intensity icon does not show up on the toolbar. Where is it and how to get it to be visible?
Shannon D
Re: Cue List Buttons and SubMasters
Post by Shannon D »
Open the cue window and make sure it is all clear. If not, clear it out. Open each of the sequences you created, save it again, but check "add to cue". Add all the sequences to the cue that you want to, then save cue. Open the submaster and click open cue. Drag and drop the cue into an empty submaster. You can build your cues so that all the colors are in one cue. Build another cue with movements, another for shutter settings and so on. So that when you create your submaster channels, submaster 1 controls colors, submaster 2 controls movements, submaster 3 controls gobos, submaster 4 controls shutters and so on. You will end up with several hunderd combinations of color mixing, different movements, strobing, etc.
Post by LJ_krede.dk »
Shannon D wrote:Open each of the sequences you created, save it again, but check "add to cue".
there is a easier way than have to save all sequences again.
1) clear the cue list window: cog--> clear ...... (cant remember the exact text)
2) open the list of sequences: Cog--> insert sequences
3) drag and drop yor sequences from the list to the cue window
4) save the cue: cog--> save cue
As shannon D said, open the submaster window and click on the button open cue. now you can drag and drob each cue to the submasters.
for the cuelist buttons there is another cog to the right in the cue window, press on that and select insert cue (again, cant remember the exact text). drag and drop your cues to the buttons.
I think all this info is in the help file in Freestyler.
mobilegreg
Thanks, that got me going with the cue list buttons and submasters. Somehow I was missing a step in there. What about the Master Intensity icon. It does not show in the toolbar on my laptop, but on a desktop system I installed on, it is there. How can I get it to show on laptop install?
