Possible to save "All" to a button? Topic is solved
keykiller
Post by keykiller »
Hello!
My Problem is the following:
I Have 8 Moving-Lights. Each on them has got an own moving-courve defined.
There are more then one moving courves (Pan/Tilt), but they should be run together.
So I want to set a Preset of the Different Courves an Strobe etc to one button, that, when I klick it, The Preset is setted and the moving lights are moving each on their own courve.
Another Question:
I have Written a Chaser for the movinglights.
I have Saved it via "Save + Add to buttons".
Do I just save the one Scene in that way or do I save the complete Chaser?
How can I save a complete Chaser to a button?
Is it Possible to save just the pan/tilt values in the Chaser, so that everything else is settable during the run of the chaser?
If I connect 4 LED Beams to the Interface, is it Possible to run a different Chaser/Programm for the LED Beams?
So that I write one Chaser to run with the moving lights (But just Pan/Tilt values, perhaps also Focus an Iris) and one for the LED-Beams, so that I can run them independently?
e.g. each on an own Button, and in one Chaser is then the LED and in one is the mvh and I press then both of the buttons and the mvh and the leds do the job at the same time, and if I want the leds to stop, I just unklick the leds button?
Sry for my Bad English ^^
Greets, Tobi
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Re: Possible to save "All" to a button?
Post by matt »
To run a MultiStep Cue, Use the Cue List Screen to "Play" the Cue back.
Matt Hankosky
flickr.com/photos/mattxhank
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
For the first question.
make a new cue list with all the cues you want to run together
save the cue by pressing the cog.
then add this to the cue list buttons to the right.
Clicking the button will then play all your saved cues together.
