Change Speed Topic is solved
zkzZz
Change Speed
Post by zkzZz »
I have two Moving Heads and want to move the the Light from one point to the other.
Ok, thats not the Problem.
But when I want to make the light faster, I create a new Step and change the Speed in the new Step. But then, there is a short Break!
Now my Question:
Is that the right way/How can I change the Speed without making a brake?
aquas
Re: Change Speed
Post by aquas »
change the sliders(0%-100%) on the cue window.... it's an option..
zkzZz
Re: Change Speed
Post by zkzZz »
No, that wasn't the thing I wanted...
But I found an option: I must change the resolution in the Pan/Tilt Window (Moving Head)
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Change Speed
Post by Mattotone »
You will also need to adjust the fade time when you create your sequence. I.e A scene time of 5sec means it waits for 5 seconds till it moves to the next scene.
If the fade time is 4sec then it takes 4secs to move to the new position and waits 1 sec untill it moves on
Tom
Re: Change Speed
Post by Tom »
Basically, expending on what Matt said, you need to have the Scene Time and Fade Time values set to the same.
