First have you tried? Log in to Search the Forum for help! Learn more about using FreeStyler at the FreeStyler WIKI HERE
Please do NOT post bugs here! If you spot a potential Bug please report it HEREfirst then you can chat about it with other users in the appropriate section.
In Addition to that, you can try to change your Resolution, beacuse Freestyler don't check it. So it can happen, that the Cue Window is out of the area you can see. I had the same Problem with a small Notebook.
