XBox 360 Controller Topic is solved
zkzZz
XBox 360 Controller
Post by zkzZz »
Is it possible to use the Triggers of the XBox 360 Controller?
I just can set up the Buttons, but not the two triggers and the LT and RT buttons.
Can you help me?
Thx, zkzZz
bckeeping
Re: XBox 360 Controller
Post by bckeeping »
Hi There,
You could also try using glovepie to take the xbox controls and turn them into midi, which you can then pump back into freestyler using midi-yoke
So the two products are :
glovepie
midi-yoke
and you need to write a little script, which is really easy using commands like
midi1.c0 = joy1.left
Which will output a c0 note in midi whenever you press left. Then just assign that note in freestyler and you are away :)
I use it with wiimotes and it is pretty straight forward
zkzZz
Post by zkzZz »
Ok, i'll try it :D
