What Interface Do you Use / Recomend?
matt
- Admin
- FreeStyler Version: NULL
Looking to upgrade. want to see what people use!
Matt Hankosky
flickr.com/photos/mattxhank
- remco_k
- FreeStyler Version: N/A
Re: What Interface Do you Use / Recomend?
Voted enttec pro.
Can I vote against one?
People should avoid using the Velleman K8062/VM116 because of its internal speed limitations when using more and more DMX channels.
matt
- Admin
Maby we should use the DMX wiki for this or the FreeStyler Wiki... Create a Page with Interfaces, then a page for each interface with User Reviews...
Matt Hankosky
- remco_k
I did create a page on the DMX wiki:
http://www.thedmxwiki.com/dmx_usb_inter ... m116_k8062
And here are all the usb interfaces that are currently documented:
http://www.thedmxwiki.com/dmx_usb_inter ... interfaces
So in fact, its already there.
aquas
I use Enttec Open Dmx, but i recomend the PRo version... some day i will buy one... if you want a non "professional" interface use the Open Dmx.
dmxlights
I have the Velleman K8062 (2) and a friend of mine has one. I bought them as a kits and put them togeather myself.
We both do lighting and have ever had a problem with these interfaces at all.
I have used mine in about 4 local theaters and in one of them I was using over 180 channels and had no problem with delays at all and that was one big chane from one to the other.
I have wote my own software for the interface but it is very basic and it does the job I need it to do.
The resion I have started to use freestyler as it has sound to light.
Tony
Tony
- remco_k
[offtopic]dmxlights wrote: I have used mine in about 4 local theaters and in one of them I was using over 180 channels and had no problem with delays
... yet. You were in luck or did'nt notice. That interface is just not a good one for larger setups.
Try running more channels, doing all kinds of stuff and then try to flash a strobe or par with an override button. You'll see it will take "a long" time (up to more than a second or so) before the light goes on, instead of immediately.
Search for posts from me about the VM-116 / K8062 (they are the same). Yours is'nt different.
Since you have no problem with delays at the moment, there is no reason to buy some other interface. But one day you wil... Then think back of what I posted here and just buy another interface.
[/offtopic]
cccy
What's the difference between both interfaces? What functions does the Open version not have?aquas wrote:I use Enttec Open Dmx, but i recomend the PRo version... some day i will buy one... if you want a non "professional" interface use the Open Dmx.
- remco_k
Already been spoken about several times: http://www.freestylersupport.com/fsforu ... =846#p2820cccy wrote:What's the difference between both interfaces? What functions does the Open version not have?aquas wrote:I use Enttec Open Dmx, but i recomend the PRo version... some day i will buy one... if you want a non "professional" interface use the Open Dmx.
jankovmuz
open enttec DMX512 from KWMATIK , simply and easy to use,good quality
jpk
I recommend the list gets updated! Missing these interfaces
ultraDMX
ultraDMX Micro
ultraDMX RDM Pro
ultraDMX Pro
eDMX1
eDMX4
ultraDMX
ultraDMX Micro
ultraDMX RDM Pro
ultraDMX Pro
eDMX1
eDMX4
cool daddy
I use a DMX4all stage pro MK 3 (MKII is listed here, update?) This is really plug and play, and only 119 euro!
- buttza
- FreeStyler Version: 3.6.4
I use DMX King. It is built on similar design to Enttec Pro. Never misses a beat.
sun137
I use MCSWE USB-DMX BOX.
It can work in any windows version (including 64-bit system), usb-hid device.
The interface sends DMX data speed is very fast. Never misses a beat.
Nathanrs93
- FreeStyler Version: None
I use the Enttec PRO. I've had no problems with it what so ever and its been good and does the job it's suppose to.
mgruenauer
- FreeStyler Version: 5.3.1
ANY BODY HELP WITH THE DRIVER FOR MY DONGLE
WE HAVE NEW COMPUTER AND NEED THE DRIVER.
IN THE OLD COMPUTER THE SET UP USES UDMX FOR SET UP DRIVER
DONGEL HAS NO MANUFACTURE OR MODLEL ON IT
WORKS GREAT ON OLD COMPUTER NEED DRIVER TO PUT ON NEW COMPUTER
Nathanrs93
If it used the drivers from UDmx then download them and try them again? Simples
- buttza
Updated, Now using DMX King eDMX2 and eDMX1 AS backup. They are awesome units. I can use these with any software that uses ArtNet.
lindsayward
Will this poll get updated? The DMXKing interfaces have a number of happy users. It would be good to see them on the list?
While we're at it, updating the text to "recommend" (two m's) would be good too
Thanks.
Thanks.
- djSupport
This Poll! was only for Matt to get views on what to upgrade! if you wan't a general one then hell I'll make a new one but that's why it's not up to date duh!
freestylerrocks
Hey I don't see the Gus Electronics USB-VL344 on the list and it works great!
Had it for years and only cost $57.00.
I'm not trying to advertise for them haha just figured you guys would want the info.
Here's their website:
http://www.guselectronics.com/
tommy100010
- FreeStyler Version: 3.5.9
- I Use FreeStyler for: Band
Thanks for all the replies ... I'll choose one of the more popular...
DO NOT BUY CYL 6602 USB512 from China... there is at least one confirmed virus on the install disk and other files which of which windows finds suspicious... plus nothing works...
romanoid
I've been readind forums and such for a day or two now....
Came up with theory, as long as dongle has FTDI chip not some kinda wanabe you are set to go?
Correct me if I am wrong...
Enttec open dmx uses one and few others as i noticed... So do one of those China cheapos I found but not the one I bought sadly...
Extra question, what people consider slow PC? It was mentioned in enttecs video about Open dmx and here as well... I am planing on dedicating my old laptop to this purpose only, 2ghz dualcore 4gb ram... Will it be considered slow for rendering dmx timings?
cralmu
i bought a GUS and it does not work... if the FTDI chip is a replica, is there anyway to get it to work.... the first GUS i bought works great, but this second one is not recognized and the drivers will not even see the unit...
