Does anyone know if any Abstract Clubscan Fixture profiles exist?, as they are not the newest fixture around I was wondering if they had been included in a previous version of freestyler and removed for V3 (ala roboscan 812)
any help would be appreciated,
Regards
Simon
Abstract Clubscan Topic is solved
- dmxlighting
- FreeStyler Version: beta
Re: Abstract Clubscan
Hi Simon
I would think that any old profiles would still be included in the lastest release.
Not every fixture has had a profile written for it. Users tend to make their own and the post them for others to download.
Its really easy to make your own profile. Have a look at the software,its stand alone to FS and can be found in the FS folder from your start button.
Its called 'Fixturecreator'
You may also need to make a 3d vis profile for it too. This is a bit more tricky but worth the effort.
If you get stuck just asked for some help and Im sure you will get it.
Lee
Lee
