sequence
villeric
Just started using FS
FreeStyler Version: 3
Instagram: villeric
sequence
Post by villeric »
hi everyone!
does someone speak french?
i don't understand how to create a sequence.. can you help me?
i create it but the software do not save my steps and i don't know why.
can we have a timeline as in sweetlight?
thanks a lot.
Eric
Re: sequence
Post by LJ_krede.dk »
try to read the help file in freestyler or look at this topic
FreeStyler Version: N/A
Re: sequence
Post by remco_k »
villeric wrote:hi everyone!
Sorry, you need to be doing this in English.
If the above hint from LJ_krede.dk did'nt work out, then tell us what you do and what buttons you press.
Maybe we will see what you are missing.
In short:
1. Open the sequence editor
2. Set some values of fixtures
3. Click the [+] to add a step
4. Repeat step 2 and 3 for each step you like.
5. Press the save button (NOT the save-all as that saves the current values of the fixtures to all steps)
6. Do what you want, like press the 'play' button.
Re: sequence
Thats not true mate I dont mind you posting in any language you like if it helps you get the answer you want.........
villeric
Instagram: villeric
Re: sequence
Post by villeric »
hi!
i'm doing exactly this: :
4. Repeat step 2 and 3 for each step i like.
6. press play
and nothing happen :?: :?: what can i do :(
do you know how to have a tomlineline as sweetlight too?
villeric
Instagram: villeric
Re: sequence
Post by villeric »
oh i'll retry then i think this is what i've done.. click "save to all steps..."
thanks, i'll come you back.
but if i do all step as you said here, and i click the little "play" button, some tiime it's not working...
