Programming LED PAR 64 outside cues
mikecheckoff
Post by mikecheckoff »
Hi!
How can I handle my LED-PAR 64 for example in function of chaser or permanent.
When I run a cue the LED-Lamps switch out, because in the programmed cues of my moving heads and scanners, the LED-lamps
are not included.
Do I have to programm they in my cues with fix DMX-data?
I have tried the DMX400 function but the lamps switches off again.
I use the latest 3.0 version and there is a option (remove fixure from playback) but there is the same result.
How can I manage to handle my LED-PAR64 independently of my programmed cues of the Moving-Heads?
Thank you for your answer.
Greets from Bavaria (Germany)!
Mike!
dmxlighting
FreeStyler Version: beta
Re: Programming LED PAR 64 outside cues
Post by dmxlighting »
MMm not sure what your doing wrong here.
The dmx400 is like a seperate program so if you have setup correctly then that should work.
Make sure that you have told the PARs that they are to be used in this way.
Example - rightclick and set 'Use in DMX400' then assign a channel number to each fixture from 1 to 12.
When you play back your cues for the moving heads etc. are you using the cue window or submasters.
If you are using 'cue' then as a default it will only play back one cue at a time. You can change this in FS setup options.
Hope that helps
