Abstract VRX Family (Scan, Colour, Gladiator)
Download other Magic 3D Easy View Fixture files created by the community here.
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
Thanks to Adam we now have a new place to upload 3D vis fixture files.
If like me you have rewritten a badly made profile or made a new one from scratch, put it here for all to use.
Please make sure your work is as close to perfect as possible or it will somewhat defeat the object!
This zip contains Abstract VRX SR (Scan) CR (Colour) and GR (Gladiator)
(note that the gladiator profile is the same as the scan. The beam output could never show the real life multibeams!)
Also Ive included the PDF of the manual.
Abstract VRX.zip
Enjoy!
Re: Abstract VRX Family (Scan, Colour, Gladiator)
You like to support Fs? then support the wiki by creating a page for this fixture and uploading the zip and pdf seperatley and any other info to http://www.thedmxwiki.com ;-)
dmxlighting
I want to but cant figure it out. I'll work on it at sme point!
Its easier than you think go to the playground and do what you like (its the place to practice!)
dmxlighting
I'll jump on that later :D
Thanks !
Return to “Magic 3D Easy View Fixture Files - User Created Downloads”
