Hi everybody,
I would like to buy 2 American DJ Tri Phase (http://www.americandj.com/ProductDetail ... txtSearch=) but I don't find the fixture, and I don't know how to create it because the 1st channel is special ! (http://www.americandj.com/pdffiles/triphase.pdf page 6) Someone can help me ?
Thanks,
Jérôme
Sorry for my bad english but I'm french...
- FreeStyler Version: 2.96j
- Shannon D
- FreeStyler Version: 3.3.2
- I Use FreeStyler for: Band
Re: American DJ Tri Phase
There is nothing special about channel 1. Make channel 1 the color wheel. The manual does not list what the colors are at the different channel values. You will have to hook up the light and figure out the channel values that match certain colors. Then you assign colors to a channel value. You can use macros for the rotations on channel 2. Channel 3 is strobing and channel 4 is your dimmer channel.
thank you for your answer !
