Bump button to full intensity
- FreeStyler Version: 3.0.1
Is there a way to bump a fixture (par can) up to full intensity with the touch of a keyboard hot key similar to on a NSI controller? I found that function on NSI very usefull. Thank you very much!
- aquas
- LJ
Re: Bump button to full intensity
you can create a sequence with the full intensity with all channels that you want, than save it and assign to a override button... in the setup-> keyboard shortcuts assign a key to the button that you insert the sequence...(do you want something like a "Full On"?)
cumpr
cumpr
Well for each individual par can that I have set to a channel I would like to be able to press a button to enable that channel to go to full intensity when I press it and then when i let go have it go back to normal. (see NSI bump buttons). thank you very much for your response.
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
2 ways.
number one. Create a scene for each of the par cans at full intencity.
Assign the scene to an overide and assign a keyboard short cut to the overide.
If its a mid keyboard, use the midi to dmx function in the setup. or assign midi note to the override.
- aquas
- LJ
On override button(on that you insert the scene)... right mouse button and set "flash button", it happens like you want... if still pressed it sill on, if you left go than off. I use it on the ACL lights...
cumpr
cumpr
Awesome! That is a major help!
