Briteq - BT 36-L1
LJ Robin
Briteq - BT 36-L1
Post by LJ Robin »
Hello everybody,
This fixture contains a led moving head from Briteq = beglec or jb systems , named BT 36-L1.
It has 8 channels or 15 channels. I wrote a fixture for 15 channels , you can set this on 8 or 15 channels with a button on the moving head.
So set the movinghead in 15channel mode or this fixture will not work !!!
You can set this movinghead into 15 channel mode by pressing the MENU button until ChNd is shown on the display.
Press the ENTER button so the display starts blinking
Use up or down to select the 8 or 15 channel mode.
Once the mode is selected press the ENTER button to setup
Press 8 sec. on MENU to save the settings
So it has 15 channels:
1 Pan
2 Pan fine
3 Tilt
4 Tilt fine
5 Pan/Tilt speed
6 Pan/Tilt movement macro
7 Movement speed
8 Special function
9 Dimmer
10 Strobe
11 Red
12 Green
13 Blue
14 Color/chase/fade
15 Chase/fade speed
I hope you'll have something about it.
Sorry for my bad English but I'm from Belguim :D
:fs:
Tested:Yes
Version 1.0
BT-36L1.pff
Fixture Briteq-Bt 36 L1
(72.59 KiB) Downloaded 29 times
mabrev
Re: Briteq - BT 36-L1
Post by mabrev »
Thanks !! :D
I'll use it soon 8-)
(BTW I'm from Belgium too ^^)
LJ Robin
Post by LJ Robin »
No problem man ! :lol: I like to help people , let me know if you like the fixture.
Grtzz Robin (P.S: Belgen zijn de beste :P )
