My sequences don't show up in the Cue!
				bellhadley
 - FreeStyler Version: 3.0.1
Hey there!  I've been using Freestyler for about a week now and love it!  However, I can't wrap my mind around what I'm doing wrong.  I have created about 9 different sequences and I add them to the cue and add the buttons when saving.  When I go into the cue, only 3 sequences show up.  If I try to insert a sequence that isn't in the cue, it comes up in offline mode.  I will go back into one of the sequences that isn't showing up and simply resave it, and voila! there it is in the cue.  But if I close out of Freestyler and come back in, its gone again with only 3 sequences in there as before.  What am I doing wrong?  Thanks for you help!
				bumclouds
Re: My sequences don't show up in the Cue!
I'm having a bit of trouble understanding your question.
You have a cue, and you want to add a sequence to it, but your added sequence won't stay in the cue?
I'm doing it right now and it works for me. This is what I'm doing:
Load up the cue, and drag the new sequence onto it.
Go "save cue", and retain the same file name. i.e. overwrite your existing one.
If you retart freestyler it should still be there!
Let me know how it goes.
				bellhadley
Hi!  Thank you for responding.  Maybe that is my problem.  I don't see a "save cue" anywhere.  I've looked and looked but don't see a thing.  I'm sure its so easy and right in front of my eyes, but I'm missing it.
				bumclouds
In the "cue" window, click the cog icon, which is next to "fast cue switcher".  Then click save cue.
If you're still stuck go to help > topics > "playback sequence" and look at that
