Martin 2510
dmxlighting
FreeStyler Version: beta
Martin 2510
Post by dmxlighting »
Does anyone know if the Martin 2510 playback unit will see all the fade times and scene times per sequence created in FS ?
Or will it just playback the DMX levels 'As Is' at a predetermined speed / snap (predetermined by the unit itself?)
Also is it or will it at some point be possible to merge several scenes / sequencies together. ?
My reason for this is that I currently use FS with submasters so I would have a sub for movements, a sub for colours, a sub for gobos etc.
Then I can overlay different effects and create unique shows.
I want to merge some of these files for uploading to a 2510. Other than that its a case of writing whole sequencies from scratch which would include all movement, colour, gobo control in one.
lj_raph
FreeStyler Developer
FreeStyler Version: 3.2.1
Re: Martin 2510
Post by lj_raph »
Hi
The 2510 controller doesn't support fade times, if you want to use fade times you must program them with the speed channel of your fixtures.
I will look for a solution to merge several sequences together.
Best regards
Raph
Raphaël
dmxlighting
Re: Martin 2510
Many thanks Raph!
Lee
dmxlighting
Re: Martin 2510
lj_raph wrote:Hi
Best regards
Raph
Did you ever look into file merges ?
