DMX-in does'nt work ?? (or does-it??) Topic is solved
ziggy2
Post by ziggy2 »
hello
in the freestyler (3.0.1) setup it is impossible to activate "Enable external control" for DMX-in
is this just normal (impossible) or is-it a bug ??
I get ENTTEC DMX PRO widgets and the "IN" works fine with other softwares
(I know that we can't use the IN and OUT simultaniously....but with other softwares the IN alone works fine - or IN and OUT with two different widgets- and I have more than one widget anyway
but I saw also that the "IN" works fine with the D2XX drivers, but won't work with the Com-Port drivers....(Schwartzpeter uses the D2XX drivers for exemple)
any ideas ??? :geek:
while searching in the forum, I saw that the question has been invoqued allready...
It seems that the external control via DMX just does not work !!! but why is-it in the FS-setup if it doesn't work ???
Android Dev (Moderator)
FreeStyler Version: BETA
Re: DMX-in does'nt work ?? (or does-it??)
Post by Mattotone »
The dmx in is for one dmx interface, i cant remeber which it was but unfortunatly was not the enntec
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
Was it for the Martin dongle ?
ziggy2
Post by ziggy2 »
thanks.....
