fixture files Topic is solved
kindlefire
fixture files
Post by kindlefire »
Hey everyone im not asking for anyone to make these for me just wondering if they already exist
Chauvet Elan Led
Chauvet Derby X Led
If not i will create i have a friend starting freestyler and he doesn't have a bit of knowledge about this stuff thanks for any help.
John
dakaraokedj
Re: fixture files
Post by dakaraokedj »
also looking for the elan profile any youtube vids or etc that can help me learn to use fixture creator? ty
dakaraokedj
Re: fixture files
here is what i have so far
DMX channel values
1 red
000 - 010 off
0110-225 on
2 green
000 - 010 off
0110-225 on
3 blue
000 - 010 off
0110-225 on
4 strobe
000-005 no strobe
006-010 blackout
011-255 slow ---fast
Elan.pff
(25.21 KiB) Downloaded 23 times
Re: fixture files
Post by Jan_K »
Hej dakaraokedj.
I had a quick look in the fixture file.
I am not sure what you want to achieve with the two color wheel channals
You only have a setting the control the red and one that control the green color.
If I had to do this fixture I think I would delete them and then create it in the macro.
Also so you have Intensity and lamp channel set to channel 4.
You should delete them.
Channel 4 is only strobe. (And that one is filled in correct)
Just a note change the "Created by" text :o)
