Determine the order of fixtures when using the FX Generator
Milo
FreeStyler Version: 3.01
Post by Milo »
for me it would be a real benefit if I could determine the order of fixtures when using the FX Generator. At the moment, if I understand it right, the order depends on in which line the fixture is listed in the fixture list. This is more or less static. It would be really cool, if I could determine it from sequence to sequence. Two suggestions, how it could be done
1. Using the order of activating (clicking) the fixtures when making a new sequence
2. A new list where I can drag and drop the fixtures in the order I want to use them in the FX Generator
Thanks for this superb programm
Best Regards
lj_raph
FreeStyler Developer
FreeStyler Version: 3.2.1
Re: Determine the order of fixtures when using the FX Generator
Post by lj_raph »
Hi
The next release of FS will have this behaviour and some more extra FX added.
If you like to test the beta version just send me an email.
Raph
Raphaël
Return to “Ideas and Remarks”
