can you use the keyboard shortcuts to advance cue to cue?
				tommyb2n
 - FreeStyler Version: 3.0
i am wondering if there is a way to jump cue to cue using keyboard shortcuts. i am wanting to advance cue to cue in my cuestack, but using only one button. i am tying to program my etc element console. i am going to program that to a rosco keystroke, then to a keyboard shortcut to contorol my martin mac 250's. i have found a couple things, but i was wondering if anyone had done something like this? it would make my program much easier if it was only one button to advance, but i am up for any options. thanks in advance!
 - FreeStyler Version: 4.01
Re: can you use the keyboard shortcuts to advance cue to cue?
You can make a keyboard shortcut to activate each sequence (use your F keys if you like) Then just hit the key when you want the sequence to run.
Rusty
						Rusty
- dmxlighting
 - FreeStyler Version: beta
To do this...
Setup - Freestyler setup - External control - Keyboard shortcuts.
Then all you do is assign keystroke button to the relevant controll you want.
The bit you want is listed from 'Toggle Submaster 1' onwards............
