Problem with freestyler
				gabbagandalf77
 - FreeStyler Version: 3.0.1
			It´s my first time using freestyler and generally DMX. The Spots and scanners i use for my partyroom are not included in freestyler. After long time and trying diffent things i´m able to create the *.fxt files with the fixture creator. But how can i create the *.ssl files for the scanLibrary so that i can insert my spots and scanner in freestyler or Magic 3D EasyView? Thank you for help!
				Snowcat
 - FreeStyler Version: 3.2.1
Re: Problem with freestyler
Make/Model of fixtures?
If a popular or well known light, it's possible someone has already made a fixture file you can use.
  User made downloads are available elsewhere in the forum.
				gabbagandalf77
Thanks for help
