I've bought a new laser (Silverstar LT-212 Club Pro II which needs 14 DMX channels, I'm using my Laserworld CS-200 file as a base because many of the functions are the same. When I'm trying to save the fixture file it says " Subscript out of range"
Is there a limitation on the amount of DMX channels.....
My next " project " is going to be a fixture file for a Eurolite LED wash which needs 24 channels....
Creating new fixture file with 14 DMX channels
Scartio
- FreeStyler Version: 3.0
- remco_k
- FreeStyler Version: N/A
Re: Creating new fixture file with 14 DMX channels
The limit is 32 channels.
Report that as a bug please, with as much as info possible and how to reproduce the problem.
[bugreporting][/bugreporting]
Then try to create the fixture file from scratch, see if that helps. If not, then tell that in the bugreport also.
