I have trouble with the 10 first dmx, when I put on dmx 1 it just light for some sec.
But if I put on light on dmx 11 den the light stays on.
Is it something in the settings that I can fix the first 10 dmx?
First 10 DMX Topic is solved
Re: First 10 DMX
i am not sure i understand your question? what do you put on dmx 1? try to be more specific and give some more details,
Lydmann
Re: First 10 DMX
I just put on a normal Par64 light.
I have tried with different dimmers but it’s something in the software that dose it.
So when I turn the fader on the software to 100% it stays there for 7 sec and then it shuts down.
Re: First 10 DMX
in FS, go to edit --> Show output and look if FS is doing the behavior you are describing
Lydmann
Re: First 10 DMX
It shows nothing there.
I see the fader goes to 255 but it stays there like the fader.
But still it shuts down after 7 sec, but the faders and the nr 255 on the output stays the same.
Re: First 10 DMX
sounds weird!!!! i have no answers for you then. maybe some of the other user can give you a tip when they visit the forum.
aquas
Re: First 10 DMX
I think you have problems with the comunication between the interface and the dimmer... have you tried other interface?? Like using an enttec open and tried other like the pro or other manufacture?? Or you have problems in the usb cable... Ohh yes some day i lost 3 hours to find that... the usb cable didn't work correct.
cumpr
cumpr
- remco_k
- FreeStyler Version: N/A
Re: First 10 DMX
Then it has nothing to do with Freestyler, but everything with your USB interface, cabling or lights.Lydmann wrote:It shows nothing there.
So check that.
- remco_k
Re: First 10 DMX
Forgot to mention that FreeStyler has a refresh rate setting for some interfaces, maybe yours.
Try setting it faster, that may resolve your problem. As Onge says, I think this can have something to do with it.
If FreeStyler has that setting for your interface, then you will find it in the select interface dialog in FreeStyler.
If its not there, then its not.
