Hi there Everyone
i have encounterd a small problem with vista.
i read the post on how to create more than 15 steps on free styler however i run a vista machine i changed the number of steps but it keeps it the same i can only get 15 steps
i really need help so any will be apprieciated thaNKS Owen.
15 step value unavailable in vista Topic is solved
Re: 15 step value unavailable in vista
do following steps:
1) copy the freestyler.ini file to another location (for example the desktop)
2) open and edit the copied file
3) save and close the copied file
4) move it back to the freestyler directory and overwrite the old .ini file with the new one
that should do the trick
