Does anybody know how to manually change the trigger time for each cue when setting up cues to be triggered by Winamp. In the older versions you were able to just click on the Trigger Time field and manually adjust the time rather than playing around with the trigger until you get it set right. I still have the old version 2.95h that allows you to do this.. So i run this version when I need to manualy adjust the time.. However, if anybody has found a way to manually adjust this in the 2.96f version.. Please let me know...
Thanks in advance for any help...
Running Cues in Sync with Winamp Topic is solved
