DYNASTY SCAN DMX
DJSkeleton
DYNASTY SCAN DMX
Post by DJSkeleton »
If you are a mobile entertainer or event producer that is on the go, then the Dynasty Scan DMX is for you! Part of the American DJ Dynasty Series, the Dynasty Scan DMX is a compact and rugged high performance scanner – yet is still sleek and sheik – with exciting built-in programs that will help you have your “A game” as soon as you plugging it in. Or, get adventurous and design your own programs with any DMX controller. Check out the optics on this scanner – the 150W lamp output rivals much larger – and more expensive -- 250W scanners in output because of the superior optics. To sweeten the deal, American DJ has included a long life, high quality Philips brand lamp for optimal performance and colors!
Make your light show even more interesting by adding the American DJ, Dynasty Ray, with a unique “Arc”-style mirror.
Features & Specifications:
• Compact high performance DMX scanner
• 9 Gobos + Spot
• 11 Colors + White
• Operate via DMX or sound active internal programs
• Fast X/Y mirror movement
• 4-button digital DMX addressing
• 6 DMX channels
• Linkable in master/slave operation via XLR cables
• Sync up multiple units for an easy-to-set-up and run complete light show
• Operate via DMX controller or with the scanners own built-in programs
• Full focusing lens
• Compact & portable design
• Run all night – high velocity fans keeps unit cool all night
• Dimensions (LxWxH): 18.25” x 7.25” x 7.5” / 460 x 185 x 195mm
• Weight: 7 lbs. / 3.3 kg.
• Lamp: ZB-EFR 15V, 150W
Dynasty Scan DMX.pff
Dynasty Scan DMX
(44.76 KiB) Downloaded 29 times
