Fixture File Big Dipper K800 Laser Topic is solved
trax
dmmcanada
Re: Fixture File Big Dipper K800 Laser
This is my first post here. I created a Big Dipper / Seven Stars K800 profile after debugging it a little.
The manual that came with mine (ebay purchase) was close but incorrect in its explanation of the channel functions. You will see my interpretation in the pff file but here's a few notes:
- Ch1 is per manual, 0-69 shuts it off, 70-139 is music mode, 140-209 is auto mode, 210-255 is manual/DMX mode
Ch2 does nothing
Ch3 does what my manual says Ch2 does: set the pattern. It seems to have 128 patterns but my pff file has all 256 possible in case you find there are differences. 0-33 are static and 34-255 are dynamic. I went through them and picked bmp's from the existing gobo folder that give an indication of what the laser will do.
- Ch4 is "strobe" which alternates between the pattern and dots (laser positions frozen) in a few steps of speed. I set it up as off/slow/medium/fast strobe.
Ch 5 and Ch 7 are pan and tilt, sort of. Between values of 64 and 127, they seem to control up/down/left/right. At 0 it is stable in a centre position, and between 1 and 63 it moves but jumps around a lot. For other values it does unpredictable and sometimes kind of cool things. This does not obey the ranges in my paper manual.
Ch6 and 8 do nothing that I can tell.
Ch9 zooms per manual I think. 0-2=original size, 3-92=zoom, above that runs automatic zoom loops making the pattern bigger and smaller.
K800.pff- Simple K800 profile
- (519.39 KiB) Downloaded 106 times
