Error creating output thread
YOU MUST FILE A BUG REPORT HERE before discussing possible bugs.
blaide13
instlled Freestyler and Entec pro on 2 different computers. One running Windows 2000 and one running Windows XP. The Enttec installed fine and was tested and confirmed with a utility that comes on the Drivers disc that came with the Enntech pro. When I start up Freestyler, I get the message: Error creating output thread. This exact thing happens on both machines. I click ok and the program launches but dosn't seem to work properly as highlighting fixtures dosen't always work and the desktop address assigner is off by 1. I'm using 2 Chauvet Colorsplash Jr's to start and they are only 4 DMX channels each. So I start on channel 1 and should go to 4. The next fixture should start on channel 5 but Freestyler starts it on 6 and has the first fixture using channels 1 through 5 even though the light only has 4 channels. After that I tried changing the color of the lights using the color tool on the desktop, but nothing happens on or off screen. I made sure the dip switches were set correctly on the back of the lights to start on channels 1 for the first light and 5 for the second light. When that didn't work I used 1 and 6 as Freestyler dictated including the graphic dip switch illustration on the desktop. Any assistance would be greatly appreciated as I have a gig on Saturday and was hoping to be up and running yesterday.
Re: Error creating output thread
"output thread" error comes when freestyler cant find the usb interface.. have you selected the right interface in freestyler setup and chosen the right comport?
blaide13
I checked USB in device manager and the correct driver is installed. However, the com port was set to 0 and my Enntec pro is on 5. I reset and saved. rebooted computer and error message went away. Thank you soooooo much. Now I have to figure out my colorsplash JR's and Colorsplash 200b's. I read on the forum that the 200b's are not in Freestylers library. If a fixture isn't in the freestyler library, does that mean I won't be able to program it? I am hoping that is not the case because I've read so many good reviews about this software. I'd hate to have to switch because my fixtures arn't supported. I am new to DMX though so if you can point me in the right direction/previous forum posts, I'd be grateful. Thanks again.
if you cant find a fixture file for ypur fixture you have to create it by yourself.
look at this turtorial with videos: quick video on how to use Freestyler's Fixture Creator
if you still need some help, discripe your problems here: FreeStyler Fixture Files - Help & Support
Forum rules for FreeStyler Fixture Files - Help & Support
