Hi
I have been trying to make a fixture to the above Laser, but i can´t get it to work properly.
Can anybody help me with a Fixture file or better, show me how i fill it in right?
The instruction over the Laser can be seen here.
http://www.coollaser.de/he_data/downloa ... colase.pdf
I hope someone would like to help me with this problem, i have been working on it for two nights now and still not a good resault!
If you need more information, just say jo and i will send it right away.
Thanks so far.
Gtech EcoLase 40G Fixture Help. Topic is solved
Re: Gtech EcoLase 40G Fixture Help.
will you attach the fixture file you are working on, and perhaps describe the exact issue(s) you have? then its easier to help youSvane83 wrote:If you need more information, just say jo and i will send it right away.
Svane83
Hej LJ_Krede.
Kan ligesom se at du er fra Danmark, så mon ikke vi kan tage den på Dansk c",)
Jamen det eneste jeg sådan set ved jeg gør rigtigt er at indtaste de antal kanaler Laseren er på, resten er stortset kun noget jeg har gættet på og det funker langt fra optimal!.
Så vil sådan set gerne have hjælp med at indtaste det hele pånær antel kanaler, det har jeg styr på.
Men hvis en nu allerede havde lavet Fixture til netop denne laser var det jo nemt for mig at se hvad jeg gør fejl osv.
Håber du forstår hvad jeg mener.
Mvh.
Peter.
Mvh.
Peter.
- remco_k
- FreeStyler Version: N/A
Please stay with the English language here so that other users can think along or can benefit from this.
