Hey Folkes
I want some LED bar's and i found EUROLITE LED bar 324/10 RGB which fulfill my needs
I want two and it will cost 256.63 EUR inclusive freight price
is there any who have some experience whit this light? or can you suggest some other light instead? is the light intensity alright??
i don't have any LED light so i know nothing about it
I have attached some info of the light and here is a video of it
thanks in advance
EUROLITE LED bar 324/10 RGB Topic is solved
EUROLITE LED bar 324-10 RGB - light intensity.pdf- Light intensity for the LED bar
- (440.65 KiB) Downloaded 156 times
EUROLITE LED bar 324-10 RGB.pdf- Manual
- (1.61 MiB) Downloaded 146 times
- remco_k
- FreeStyler Version: N/A
Re: EUROLITE LED bar 324/10 RGB
I have used the Pixeltrack pro from Skytec few times earlier. (link)
As far as I have seen for now, it has more different DMX channel setups, up to 160 channel mode.
Don't know if this is an advantage for you and the way you plan to use the unit.
looks cool alright, but its more expensive. and yes, i think its a overkill to buy this... i want to use led bars to make some effects on stage, light up some walls and change colors. maybe use it to disco light.. a little bit of everything actuallyremco_k wrote:I have used the Pixeltrack pro from Skytec few times earlier. (link)
I have PAr cans to light up the stage and band. the LED bar's purpose should only be to make some light effects.Onge wrote:I am sure the LED bars are good for lighting low across stage or up a wall or as a visual light, but for general wash lighting of a stage and band members I do not think so.
should i be worried that the red light is 1/3 less powerful than blue and green?
thanks Onge. just what i needed to hear
but what about this LED bar from Eurolite? is it okay for my purpose? and the price ?
Tom
I do not have any experience with the unit in question, and the only RGB bar I have VERY limited experience of are these http://www.pixelrange.com/pixelrange/product_1044.htm
Have a look at the pixel-line stuff but it may be over your budget.
Tom
Tom
actually, the price i mentioned was for two LED's = 256.63 EUR not included tax ( we dont pay tax in Denmark when we are a organization), so the price is almost the same.Onge wrote:I have found it much cheaper at http://www.lighting24.de/product_info.p ... s_id=17744
the angle for the EUROLITE bar is 30 degreees... i thinks thats okay if i will use the light both as a wash and as an effect, dont you think?
thank you all for the comments and suggestions.
the Pixel Track and pixel range look cool but way over my budget. I have ordered two of the Eurolite LED bars and cant wait to play whit these two.
I have already made the fixture file and will upload it as soon I have tested it. I will let you know how I think the LED bar is like
