Master Intensity Topic is solved
arabianknightone
Master Intensity
Post by arabianknightone »
Can't seem to get the master intensity to work with any of my lights. I have 12 par cans, 6 trackspots, 2 powerscans, 4 Mac 250 Wash fixtures, 4 Mac 250 Entours, 8 Mac 250 Kryptons, 2 Mac 2000 wash fixtures, and 12 LED fixtures. Can't get it to work with any of them. Can anyone tell me what I'm doing wrong?
ziggy2
Re: Master Intensity
Post by ziggy2 »
maybee I'm wrong but I think the Master-Intensity only works with Cues and Submasters
to change Intensity on groups or single fixtures you have to use "intensity" (is different from Master intensity!!)
arabianknightone
That could be correct. I checked all the fixtures and the fixture files and everything is setup correctly. So what you say about it controlling the intensity of the cues and subcues makes sense.
ziggy2
Post by ziggy2 »
just try and you'll see:
just create a sequence put it into the Cue-list, run it and the master-intensity should work...... (I use the master-intensity constantly on my submasters (and also on the Cues)
