Sequence Order in queue window
Raiden
Post by Raiden »
Hi Everyone.
How can we change the order of the sequences that I have added in the cue window???
It's probably simple but I just can't find it!
Thanks!
:fs:
FreeStyler Version: N/A
Re: Sequence Order in queue window
Post by remco_k »
- Remove the sequence you want to change position
- Press the cog, choose insert sequence
- Drag & drop from the "Insert sequence" form to the preferred position in the cue forum.
FreeStyler Version: 3.3.7
Post by LJ_krede.dk »
remco_k wrote:- Remove the sequence you want to change position
Furthermore you can right click on a sequence in the cue window and select "insert sequence above this one" if you find out you missed a sequence in the order
/LJ_krede.dk
Aalborg, Denmark
Raiden
Post by Raiden »
Thanks for the reply.
Can I suggest to add a Drag/Drop option for this?
Thanks!
