Hi guys...
i have a weird problem with magic 3d software...
my gear is Light Sky MH8857 575W Moving Head
the problem is my moving heads Pan is turning from right to left or clockwise.... but i believe any brand or gear is doing the same thing.
while magic 3d is turning counterclockwise... i've tried setting it from scan library or fixture creator... but there is no setting for turning the moving head cw or ccw....
please help me...
am i the only one who have this problem?
thanks so much guys...
Help magic 3d moving head turns ccw Topic is solved
rrlighting
Re: Help magic 3d moving head turns ccw
oo and i also have small problems... is it a bug or just stupid me....
in freestyler theres a blackout toggle and favorite toggle... when i press the blackout toggle.. nothings happened... but when i press favorite my lights goes blackout... is it normal?
thanks a bunch guys...
if the lamp don't have a shutter and/or the channel for shutter is not defined in the fixture file the blackout will not work, this can be fixed to set the shutter channel. if the fixture don't have a shutter, the channel can be set to the same ass intensity --> works fine for me in my PAL1200 which don't have a shutter
what the favorite button does to your fixture is by default to set all channels to zero..you can change this by setting you fixtures as you like and then go to "edit --> save as favorite". now the favorite button is set with the present values of each channel. you can also do that for the startup values
rrlighting
oh my God it is that simple.... thank you thank you so much...
hahaha....
hahaha....
