Cue and Submaster playback problem
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
Hi Guys
Ive found a bug on cue / submaster playback.
Ive made a submaster group called 'shutter' which as the title would indicate is for sutter control ie open, close and various shutter chases ive created.
Problem is it wont play them back! All the other subs work fine just not this group.
The chases work perfectly well if played back via the sequence creator so what is going wrong?
Also if I run the chases on the sub then shut the sub the chases work!
This is really weird and may have a simple solution, so if you can help please do or if you have had this prob yourself, let me know.
My setup was for 6 Abstract VRX scans if that makes any difference?
Also if anyone knows why the VRX profile for easyview wont do gobo rotate, or how to make it work please let me know. I have tried and failed!
Cheers
Lee
Re: Cue and Submaster playback problem
Post by LJ_krede.dk »
dmxlighting wrote:Hi Guys
cant reproduce the error.. which scan is it?... i have two different types.
dmxlighting wrote: My setup was for 6 Abstract VRX scans if that makes any difference?
If you did a search you would have found the topic "Easy 3d Color Wheel Rotation Problems"
Thomas
Post by Thomas »
Perhaps the device responds to the intensity channel?
Try the intensity up to 100%.
dmxlighting
LJ_krede.dk wrote:cant reproduce the error.. which scan is it?... i have two different types.
Im using Abstract VRX sr's (the profile is the same as vrx gladiator), I made a duplicate of the gladiator profile and renamed it so I can use 'groups' as i also have some gladiators too.
dmxlighting
Thomas wrote:Perhaps the device responds to the intensity channel?
Thanks! If I put the submaster intensity up to 100% it works! Obvious really.
