Generic DMX 4-Channel Dimmer? Topic is solved
bumclouds
Post by bumclouds »
Hey guys,
I have just switched from Light Jockey to Freestyler.
We have a whole heap of lights in the room, which are controlled via a 4-channel DMX dimmer.
They used to work under Light Jockey by making a fixture called "Generic 4-Channel Dimmer" - but I can't find somesuch thing in Freestyler.
I tried "Eurolite Dimmpack 4 Kanaals", and I got a response out of that - but sadly just Fully on, and Fully Off, and nothing in between.
Any help is greatly appreciated!!!
:geek: Andrew
FreeStyler Version: N/A
Re: Generic DMX 4-Channel Dimmer?
Post by remco_k »
In the add/remove fixtures section go to the "Par 64" category, add the 4 PAR64L (or R) and use that.
Or add 4 single pars. Or parcan's from the Parcan category.
Otherwise, create your own "Generic DMX 4-Channel Dimmer" with the fixture creator. Should take about 30 seconds.
bumclouds
Post by bumclouds »
Worked like a charm.
Thankyou!
