Opening old FS files in beta Topic is solved
Tom
Why can't I open a file I have created in say version 2.95f in the beta version 2.96f?
- djSupport
Re: Opening old FS files in beta
cause theres alot thats changed since then the file format may have changed you do ask many questions thomas
Tom
DJ Support wrote:cause theres alot thats changed since then the file format may have changed you do ask many questions thomas![]()
