Inverse CMY Values for High End Lights
jg5985
FreeStyler Version: 3.0.1
Post by jg5985 »
Using the fixture creator is there a way to swap the values for the CMY color channels.
all three at 255 is white with a studio spot not black as the software shows.
Thank you.
Please HELP.
I have a show soon and was not expecting this problem.
FreeStyler Version: 3.3.7
Re: Inverse CMY Values for High End Lights
Post by LJ_krede.dk »
I dont think the issue is in the fixture creator or Freestyler, but in the magic 3d viewer. I have same problem with Martin PAL1200, but works as it should i real.
try to test it in real on your fixture
/LJ_krede.dk
Aalborg, Denmark
jg5985
Post by jg5985 »
In the Magic 3D it works. For real is where it doesn't.
C=0 M=0 Y=0 -> Black
C=255 M=255 Y=255 -> White
Same is true on my Studio Colors.
Attached is my fixture file.
I know I can build a pallet of bump button for my colors but I would like to use the color pallet in the system because my show is 100% on the fly.
jg5985
Post by jg5985 »
The value representation of 0 - full color is also in the high end manual.
do you have a manual for the light?
/LJ_krede.dk
Aalborg, Denmark
jg5985
Post by jg5985 »
[freestylerdev][/freestylerdev]
