what system specs does freestyler and 3d view need to run?
gareth
FreeStyler Version: 3
Post by gareth »
hey all :)
what system specs does freestyler and 3d view need to run? im looking at buying a 1.5ghz 512mb ram laptop thats going cheap just to run freestyler and 3d view :)
cheers
Re: what system specs does freestyler and 3d view need to run?
I carnt see that being a problem as long as its stripped down and nothing else is running on it oh and XP!
FreeStyler Version: N/A
Post by remco_k »
gareth wrote:hey all :)
cheers
I run this on a similar system, 1.4 GHz cpu / 1 GB ram. (512 MB would be enough when using Windows XP)
So it would run just as good on that laptop.
The only concern is the graphics. 3d easy view uses advanced 3d graphics which not all graphic cards support. It may even not start giving you an error.
When I run 3d easy view in the most high quality mode, my laptop has trouble doing that smoothly. But it works.
Maybe you should check at sunlite's website what the system specs are for the software.
For using FreeStyler, is no problem at all.
