blacking out lights need some help
gareth
FreeStyler Version: 3
Post by gareth »
hey all,
my first problem is when i press blackout all of my lights go out in the easy view program apart from the martin mx-1s and when i click on the lamp settings and click close that still does not turn the light off :?
second is when i press blackout i would like one of the lights that runs on the dimmer to stay on is there any way i can do this? cheers
aquas
LJ
FreeStyler Version: 3.0.1
I Use FreeStyler for: Church
Re: blacking out lights need some help
Post by aquas »
hi,
you need to create a group with the fixtures that you want to blackout. Than set a button in the keyboard shortcuts, "Blackout Group *". * is the number of the group you create, so in the list is ascending 1 to ...
When you use the defined button than only blacks the fixtures you select.
cumpr
gareth
Post by gareth »
cheers that sorted the second problem :) any one got any ideas on the first one? cheers
FreeStyler Version: 3.3.7
Post by LJ_krede.dk »
gareth wrote:hey all,
if you like, maybe you can fix it by changing the fixture in scanlibrary for magic 3d.
second is when I press blackout i would like one of the lights that runs on the dimmer to stay on is there any way I can do this? cheers
you can as already said us the blackout group. you can also go to "setup --> add/remove fixtures" and configure which light not to respond to the black out button by setting a check mark at "Ignore Blackout" for each fixture
/LJ_krede.dk
Aalborg, Denmark
