hey every one,
i want to create a fixture profile for my chauvet dmx - 4 dimmer/relay pack i have the manual for it but my problem is when i go to create a new profile what do i choose "parcan, dimmer" or "other" cheers
Chauvet DMX - 4 Dimmer/Relay Pack problems
- FreeStyler Version: 3
- remco_k
- FreeStyler Version: N/A
Re: Chauvet DMX - 4 Dimmer/Relay Pack problems
Dimmer ofcourse.
Then fill in the manufacturer, fixture name and give the fixture a nice picture, fill in the total channels (4) and go to the Channel description tab.
There fill in the descriptions of each channel.
But you don't have to create that fixture file, because default dimmers are already there and will work just fine.
Go to FreeStyler, Add/Remove fixtures, go to the PAR 64 category, choose 4 PAR64 L or R, set the right DMX channel and youre done.
