When I tried to run a sequence at a certain tempo with tap sync, I noticed that the step would only go so far until it switched to the next step. I figured out that this is because the tap sync changes the speed to something faster than the fade time. I want my sequence to change steps with the tempo.
Is there any fix for this?
Thanks,
Danny
									Sync scene/fade times with tap sync?
				norcaldanny
- remco_k
 - FreeStyler Version: N/A
Re: Sync scene/fade times with tap sync?
You mean you want the fade time to be (automaticly) set faster when stepping faster to the next sequence step?
Thats not possible as far as I know. Maybe you can request that here for the next release.
				norcaldanny
OK. Thanks anyways. Although it would be a really cool feature to have.
Danny
						Danny
