Unusual Message pop-up Topic is solved
Tom
Post by Tom »
When I try and start freestyler, I get 2 bars then a message saying "Component 'msflxgrd.ocx' or one of it's dependancies not correctly registered: a file is missing or invalid"
I am using verion 2.95f (the latest stable version)
I also get this when I try and run the latest beta I downloaded (2.96d)
Anyone help?
Cheers
Tom
Re: Unusual Message pop-up
either one of the files didnt install properly or its corrupt try this :
Go to Start then Run type this in the box
Code: Select all
regsvr32 msflxgrd.ocx
then click ok and then try again...
also after that if it works do a virus/spyware scan...
Tom
Post by Tom »
The thing was - I was using it fine yesterday!!!!
Don't worry all fixed now.
Al I did was download the latest beta via the forums =]
thats why I said do a virus check something maybe tampering or just your system throwing a wobbly!
